i have a scene i just setup and testing but its rendering very blurry, no Dof on or anything i know of, anyone seen this before
Hard to see in in the thumbs, but any AA filter on?
no, no filtering on, i installed another version but at 1k it stil looks abit blurry all over but better abit, maybe its because its at 1k but usually i do all testing at 1k, far away seems ok but closer to the camera i think should be more clear, i sent a scene and description to support, to see if all is ok
test by shawn mitford, on Flickr
here it is at 1500, who knows maybe its ok now
http://postimg.org/image/mwym4w6jf/
I can’t zoom in enough to see.
last one was it at 100 percent at 1500 pixels wide, zooming in more just makes it more blurry, maybe i have fallen victim to “looking at the image too long” but i haven’t been working on it long. uff who knows, gonna leave it until tomorrow
your probably right my friend, bedtime!
Try resetting V-Ray.
did it five times now:) uninstalling and installing, not too sure what’s up
are you blurring your textures? I use VMC to globally set my blur to 1. Maybe, somehow, that gots screwed up.
all is at default, blurring at 1 and pyramidal, i increased the resolution and changed the default mapping, things look abit better, i used the same texture before in a similar setup and it was alot better but i guess i can live with this, this is how it is now
and this is how it was before, i just seem to think its stil too blurry all over, heck, will just ignore it and forget it and see what support says, i think its probably scene specific because i rendered some scenes from another file nicely today and this started happening in the middle of testing this scene, i thougth it looked good at the start then as i went on it started to look more blurry, idk
living 1.RGB_color by shawn mitford, on Flickr
What AA filter are you using?
i turned it off, i usually do for tests
what does your samplerate path looks like ?
had similar issue with undersampled scene
sample rate is just red everywhere,didnt render it out fully now the scene is done,gona have to raise the default settings and see, will post after these renders are complete
I haven’t had to mess with a V-Ray setting since 3X. Adaptive 1/24 (default) BR+LC (default). The only thing I change is the dynamic memory and I like the render to start from the middle, so I set it to spiral. I have tried lower settings, but the defaults still render faster and cleaner.
how are the sample rates?
Perfect! Most things are blue, except for edges, which are green.
