Hi Guys, would be nice to have an option to bring closer the clones inside the defined areas (splines). Sometimes you have a few clones, but they end up too far from each other. And if you size the spline down you mess with the clones.
I think you didn’t get the point. First, why don’t we get exactly the numbers of instances set on count field? Finally, inside the scattered area I can’t bring the clones close together, and if I try to reduce the spline, the instances go away.
We should have the option to make the instances close together from each other without changing the number of copies.
This might just be a ‘‘spline’’ issue. When scattering without a spline the scatter amount seems to match as expected. In any case, we will need to look into it further.
