I usually disable any VFB when rendering image sequence on renderfarm, in order to reduce memory usage and reduce a bit the render times.
It renders fine when in progressive mode.
But in bucket mode, only the initial passe is rendered, following passes are just ignored (almost instant in the rendering info window).
Don’t know if it’s a bug or just a normal behaviour.
I’m using 7.1
