Bug: VrayMtl_qualityMenu cannot be found
This is an ancient bug, I’ve reported it since Maya 2008 and i guess it might be Maya going nuts. but i’ll report it again as it is very annoying. This is on the latest build from friday for Snow Leopard 2011.
I set up a new material, let’s call it VrayMtl01. I add a texture file. I change the name of the Material to RandomMtl01.
I then want to alter the hardware texturing options. I try to flip down the menu, but all I get is this error:
// Error: Object ‘VRayMtl_qualityMenu’ not found. //
The standard hardware texture options are gone, and there is only “Texture Channel : None” available.
If I put the hardware texture options in _before_ I change the material name, then it works perfectly.
From what I remember, all materials in Maya, V-Ray or not, have this issue. Can you verify if a standard Maya Phong or Lambert material works in this situation?
Indeed, it is Maya specific. A blinn will produce the same error.
Is there any chance you can forward this bug to Autodesk? Coming from a developer, they might take it more seriously.
I’ll report it to them now on my own end.
This is not a complete fix, but a reasonable workaround.
Not tested on anything but win7 and vista, maya 2011
many thanks djx, I will try that right away! :slight_smile:
it’s impressive that autodesk has not fixed this bug already.
can confirm djx has fixed this issue with that workaround
