I regularly use a bercon tile material for floorboards and put a multitexture map in the tile slot so that a selection of board textures are used across a floor.
For the bump, I copy this bercon/multitexture into the bump slot. However, when I render, I just see the bump of the bercon joints and not the wood texture of the planks. Any ideas why?
I changed the height to 0.05m, but that was just through trial and error in this situation. A colleague has mentioned that if you put the multitexture into the colour slot 2 of the bercontile, you don’t need to use vraycolor2bump, but I haven’t tried this yet.
