C4D + Corona - Beautiful daylight
Hello guys.
Need some help with recreating beautiful clear daylight with sun like on this pictures: https://instagram.com/p/Be8lELdnOpw/
I tried different things like sky+sun, sun+hdri but nothing looks so Nice like his pictures.
He is using octane.
Thanks a lot. Daniel
Would need to see what result you are getting. So long as the Corona Sun was low in the sky, and the sky was set to use colors from the sun, getting an evening lighting like this should be simple :smiley: Or use an evening HDRI (either with or without a Sun). Then it comes down to depth of field, and maybe a bit if tone mapping by playing with the post-process settings… but impossible to say what to try without seeing what you are already getting, and what settings, HDRIs etc. you are using.
Quick and dirty try. Maybe it can serve you as a base. :smiley:
dandelion.c4d (310 KB)
