Hello guys, I’m facing an issue and thought someone may have an idea on how to solve this out.
I would like to convert some models from Corona to Vray in Cinema4d, In vray there is a material converter but it seems that it doesn’t work properly.
Thanks in advance!
Hi, I do no think it’s possible unless a third-party plugin is used.
Hi, I tried it but it seems that this is to convert it to Corona render, my scene is already in corona and I would like to convert it to Vray.
Hi JohnNinos,
I’ve developed a plugin named CoronaToC4D that converts into C4D materials.
After that you can use V-Ray converter fer second step.
You’ll find my plugin on Gumroad under my profile (Kosmos3D).
Hope it helps you.
@kosmos3d - sounds amazing! - I’ve been looking for this. I will check it out.
