C4D Material Converter
Dear Vray team!
I work with Vectorworks and Cinema 4D every day, so I hand over Vectorworks in C4D, so I always have new C4D materials that I then have to open with the old version Vray 3.7 in order to be able to convert them into Vray materials.
And then with Vray 5 The same thing , which is very, very time-consuming!
Updateting, because I have new C4d materials again if a plan has been changed then I only have the option to edit the materials manually - this is not a workflow!
I have at least 30 materials per handover, it would be very helpful if a C4D would come to Vray Matrial converter!
(Diffusions, Reflection, Bump) would be great.
Thank-you!
Hello @Wohnraumdesign ,
At the moment we can only convert materials, created with V-Ray 3.7 to V-Ray 5. Adding converter for native Cinema4D materials is on our to-do list for implementation in the future. This has already been discussed here.
Thank you for your understanding.
Thank you!
