C4D Vantage UVW Mapping
Hello
C4d zu Vantage UVW Mapping Scale functions in C4D for the Diffusion channel work but for the Bump channel it doesn’t work.
no bump scaling possible?
Is there another possibility?
If not, I ask you to fix this function as soon as possible.
Thank you
For this to work, we will have to implement bump mapping through our shading graph system.
Is it possible for you to use normal maps instead ? They should already work correctly.
Greetings,
Vladimir Nedev
C4d Vantage
I tested the normal map, the starch works but the scaling does not work.
Thank you
I am sorry, the latest 1.6.2 build doesn’t have support for normal maps yet.
I forgot we haven’t released an official build that supports normal maps.
the starch works
I am not sure what “starch” means in this case, maybe a mistranslation ?
Greetings,
Vladimir Nedev
