Camera bug??
I wonder if it’s a bug or some settings I don’t know…
When I’ m using the DOF, my background become blurring…
Attached, 2 Interractive render, one without DOF and the same with…
Is it a bug or is it because I don’t know how to use it?
thank you?
yanosh
How are you adding the background? It’s not an actual object in the scene by chance?
hello,
Yes I did, it’s a Map added in the environment overrides.
the only object in the scene are grass (forest pack) and a plane for the floor.
I’ve got the same issue with a Physcam…
Is this not just the aperture being set incorrectly? Have you tried using a targeted camera and bringing the target close to your objects?
I don’t know… I haven’t but I’ll try to
i have tried with a target camera… I can’t have dof effect!!! don’t uderstand why…
Maybe by disabling “override focus” this will work.
hello Archimi, no it change nothing..
Corona team, an idea?
thank you..
Enviroment map is always affected by DOF, but in your example it certainly looks wrong. Could you try to add new camera and see if it solves the issue? If not, then it would be best if you could attach simple scene with the issue for investigation.
all right… i’ll try.. and send you a scene.
thank you.
Yes, we will need a scene to understand what is going on here. (see my signature for uploader)
perfect…
file is uploading…
an idea:
maybe it might be interesting to add the ability to enable / disable the dof of the background…
Secure Connection Failed with your uploader
i’llsend you a link from wetransfer
here it is.
Try with the physical target camera, turn on DOF in the command panel for the camera, Set to ‘use target distance’ then go into interactive mode and adjust your aperture and focal length til youre happy.
It’s a bug. I will forward it to the devs now.
@Yanosh, thanks a lot for reporting!
The workaround is to use 3ds max Bitmap instead of Corona Bitmap.
(internal note: id=241504776)
hello, thank you… i did a test with target camera…
but i wanted to have good result with corona cam… :wink:
great!
ok for Corona Bitmap…
thank you
