Camera focus on texture?
Afternoon all,
When you look at your textures panel, I know you can select textures in the scene, but is there any way to jump to that texture?
I may have put in on an edge of something and it’s not needed, but quite tricky to identify where the textures are being used.
The goal is to reduce all textures not in use. I know there is the clear unused textures button, but I’m trying to simplify textures used in general.
Any solutions?
Best
T
Hi john_gulland,
You can right click on any material in the Asset Editor and choose Select Objects in Scene.
This will highlight every face group or component using the material.
Unfortunately this function does not highlight edges that use it.
We should think about a way to improve this behavior.
Konstantin
