Camera not work
In Corona 8, I put a Corona Camera but I can´t use ISO, Shutter speed, F-Stop, etc. I change the settings but the render remain the same. In the Render Panel I haven´t the old camera settings. What´s wrong?
If I understand your question correctly, then the answer is to delete Simple Exposure from the tone mapping stack and add the Photographic Exposure in its place. This then means exposure is taken from ISO, F Stop, Shutter Speed and not from the Simple Exposure value.
That´s Right, but your recommendation has no effect on rendering. It still not working.
All right, I found that I need to add Photographic Exposure, not only delete Simple Exposure. Thanks you very much!
You are welcome!
