Cameras with namespaces/colons won't render
Using nightly build 03/11 I’ve been having issues with referenced cameras. I believe this boils down to the fact that referenced cameras (with namespaces) use colons, which windows can’t have in filenames. This used to work in the official build. When I try to render (using Maya RV or VFB) through a referenced camera, I get the following error:
// Error: Cannot create output image file “namespace:buckCamera/masterLayer/lightingScene_v04_jk_fixingRefs/masterLayer_tmp.exr” //
I’ve gotten around this by using local cameras (duplicate special options, maintain input connections), but it’s a problem. Anyone else encountered this? Thanks,
Jens
Well I’ve found this works with default cameras, so I’m not sure what it is. I’ll post back here if I figure out what’s happening.
