Is it possible to see the Revit Linked Files? We are mechanical contractors and we link the Arch and Structural files. Without the ability to see the links, is doesn’t have much value. We have also tried to copy monitor the link, but haven’t had any success.
Hello Saldambro,
yes, Enscape should display linked models just fine - it doesn’t see any difference between linked and regular projects.
You’re saying your linked projects don’t show up in Enscape? Could you probably send us some [Feedback] using the Feedback-button in the Enscape ribbon? Please also provide your e-mail address if it’s not filled in automatically, as well as a short description, so we may check if we find a possible reason for this!
Thank you!
I cannot see the revit links on my escape model. Although I exported it from a view which all the links are on.
Please guide me
Thanks in advance
Please make sure the Revit link has the detail level set to fine. Otherwise you’re just seeing analytic lines rather than geometry. Enscape wont render lines (2D/3D/model/analytic/etc).
Can you post a screenshot of a 3D view of your project?
