Cancelling a render during LightCache Calcualtion Hangs Max
Cancelling a render during LightCache Calcualtion Hangs Max. The CPU Usage viewed in the task manager remains at between 50% and 54% and there is no option but to cancel the process.
VERY ANNOYING.
Hmm ok, well i just tried that here and had no problems at all.
What sort of scene are you rendering? is it a really large/heavy scene?
Abit more detail would be handy as well.
What vray version, max version, how much ram you have…etc.
Hey,
Im experiencing this too…theres no particular reason for it either…sometime it happens and other times it doesnt. What does work tho, is if you just leave max (stop clicking altogether in fact) and wait..it might take 3-4 mins to catch up.
My thoughts were that if it was a really heavy scene, it could just be the memory unloading type of thing.
Similar to in the scanline days, when you render a scene with lots of raytracing, and you clicked cancell. That took ages to stop.
Maybe something similar?
yeah i think your right … i think its just a matter of unloading a heavy scene… the smaller the scene the quicker the cancel… Like putting on the breakes at 100 mph … or 10 mph…
The same problem - but I can say it happens only BEFORE lightcahe or any prepasses(cancel render before any calculations)
Do you guys have more than one Processor or HT enabled?
Also what’s your “number of passes” in the lightmap?
(use a number similar to the number of your processors)
Cancel
Same issue here. My cancel is grayed out. I probably have to kill my job and start it again. I am waiting for my MAX 2009 and I’ll install VRSP2 and see if it resolves it.
Which V-Ray version is that?
Hang
1.5 SP1. I ended up merging the scene into a blank scene.
Do you still have a copy of the original problemmatic scene that you can send over to vlado@chaosgroup.com so that I can investigate?
cancel
I have since deleted it after I merged it over to a new one. If it happens again I’ll be sure to save it.
this original problem that i could replicate was ages and ages ago - probaby 1.46xx or something…
Happened to me last night. Had added some displacement and cancelled during lightcache process. Unfortunately I hadn’t saved for a while, so I decided to let the machine and Max stay on while I went to bed. Next day the “calculation” had finished and I could save my scene.
Edit: Using Max 2008 and 1.50.SP1
The same thing seems to happen in Max 2009 with Vray 1.50.sp2
Ok then, anyone willing to send a scene to vlado@chaosgroup.com so that I can reproduce and fix this?
I get this more and more 2.
max 8, vraysp2, xp64
I cancel lc calculation, then it hangs, max says “saving”, but it just hangs and never seems to get out of that, all I can do is kill max in task manager.
VERY annoying, now I have to save every time before I do a render, just to be sure not to loose anything.
oh.. as a side note: It also corrupts your max file when you kill max in task manager in this process. sweet!
If you could send your scene to vlado@chaosgroup.com I will be able to look into this in more detail.
Other than that, are you using DR? If not, do you have any idea what might be causing 3ds Max to save your scene (which is probably why it is corrupted when you kill it). Is your scene located on a network drive?
Ok, I will see if I can put a stripped version together (it’s quite large).
I am not using DR and the scene is located on the network.
I have a large area with vraydisplacement, that might be part of the problem. but funny thing is sometimes is starts immediately and if not it hangs like described before.
I have no idea why it is saving, maybe an automatic save that was trying to start?
I have 2 quad cores and the # of passes in LC was set to 8. now I changed it to 4, not had the problem yet, might that be related?
Not well tested yet, but I noticed the last bucket in my scene using SP2 seems to take an extra long time to complete. I have not tried canceling a light cache yet with this version as I only have started using it in the past two days.
