Cannot get SWARM to work
im using vray 51003 in sketchup 21.0.391 64 bit. I installed swarm on the second computer. However, when i turn on swarm on the main computer & start to render, nothing happens on the spare computer. Nothing happens in the Log or in any other part of the interface. I have a spare node license. Dont really know where to begin with troubleshooting Swarm. Am i meant to manually activate swarm aside from hitting that swarm button in the sketchup vray interface ? When should we use port 24267 vs 20208 ? My main computer has had every known port opened up, but i cant really say for sure about the laptop as i’m not in control of the firewall.
@leotchest hi,
Is it possible to get in touch with our Tech Support team so they can assist you with this issue? You can reach them via the contact form here. Many thanks!
ok willdo. thanks !
still no effective response from Tech Support team. We were supposed to have a teamviewer session this morning but nobody contacted me
this is the second appointment for remote support that i’ve arranged with Borislav S and again, no-one is showing up or even sending me the team-viewer link or giving me any idea of whats going on. What kind of support is this ? When we make an appointment, you need to stick to it or let me know “before” the appointment if you cannot make it.
Hi! Can you check your “C:\Program Files\Chaos Group\V-Ray\Swarm 1.4\work\vray-swarm\vray-swarm.log” logs at the Swarm computer after trying to do a render job?
I believe you may have the same issue as me, I described it at V-Ray 5 update 1.3 checksum mismatch with V-Ray Swarm 1.4.6 - Chaos Forums (chaosgroup.com)
Hi !
this is what i see on the render node
{“name”:“vray-swarm”,“hostname”:“HPZBook”,“pid”:15576,“level”:30 ,“msg”:"Trying to start V-Ray version ",“time”:“2021-05-03T04:30:55.530Z”,“v”:0}
{“name”:“vray-swarm”,“hostname”:“HPZBook”,“pid”:15576,“level”:30 ,“msg”:“No version given and no default version found”,“time”:“2021-05-03T04:30:55.531Z”,“v”:0}
{“name”:“vray-swarm”,“hostname”:“HPZBook”,“pid”:15576,“level”:20 ,“msg”:“Serving / from C:\\Program Files\\Chaos Group\\V-Ray\\Swarm 1.4\\swrm.nar\\frontend\\build\\vray-swarm”,“time”:“2021-05-03T04:30:55.551Z”,“v”:0}
and this is what i see on the master
{“name”:“vray-swarm”,“hostname”:“LC00”,“pid”:31540,“level”:30,“m sg”:"Trying to start V-Ray version ",“time”:“2021-03-24T18:18:09.113Z”,“v”:0}
{“name”:“vray-swarm”,“hostname”:“LC00”,“pid”:31540,“level”:30,“m sg”:“No version given and no default version found”,“time”:“2021-03-24T18:18:09.115Z”,“v”:0}
{“name”:“vray-swarm”,“hostname”:“LC00”,“pid”:31540,“level”:20,“m sg”:“Serving / from C:\\Program Files\\Chaos Group\\V-Ray\\Swarm 1.4\\swrm.nar\\frontend\\build\\vray-swarm”,“time”:“2021-03-24T18:18:09.127Z”,“v”:0}
Do you get anything else after trying to do a render job?
Because if you only see that, it’s not receiving the jobs at all.
no - didnt get any messages or anything. The master computer renders without any problems and i can “see” and ping the render node over the network - but it just wont render, despite having added exceptions to the firewalls and also having turned them off completely
I just tried with the same version as yours, V-Ray 5 update 1.2 (51003), and I get the same issue, it won’t connect to the render node at all.
And well… The latest version, as I stated above, it does connect but I get the checksum mismatch error :frowning:
ok i didnt realise there was a new version - i thought there would be an auto notification. never mind, i will give it a try & see what happens !
Tried it - made no difference
Hey @leotchest ,
Apologies for the inconvenience you’ve experienced. We had some issues with receiving mails from clients, but it should be ok now. Someone should have contacted you already; thanks for the understanding!
