Can't connect Oculus Quest 2 to Enscape
Hi all, quite new to VR. Our setup is using sketchup, enscape and oculus quest 2. We’ve connected the VR headset to the PC via the oculus software, press the VR button within enscape and nothing happens, soemtime the headset goes black but nothing happens. It’s a pretty new PC with not bad specs so wouldnt have thought it would be that but not 100%.
Any suggestions?
Welcome to our Forum.
Please make sure to also acquire and start Steam + SteamVR before being able to make use of Enscape VR with the Quest 2/1. That should do the trick but kindly get back to me in case it does not or in case of any further questions.
Hello, I am using enscape 3.3. PC is powerful enough. I also tried with Steam VR but a black screen comes up. What do I need to do for it to work? Will it be effective if I downgrade the Enscape version? I would be glad if you help. We bought the Oculus, I don't want it to go to waste.
