Cant enter numeric values of 0.9 - 0.8 in frame buffer
HI, we are using corona 9, in the new frame buffer we cant enter values that start by 0.
Just values from 1 and up. If you use the spinner the values can be less than 1 .
There was an issue like this in one of Corona 9 daily builds. Are you using a daily build or the final release from Download | My Chaos
Also, what is your Windows language? Is it English US, or some other one?
Hi, currently on corona 9 oficial release
Windows language Spanish
Are you using Windows 10 or 11?
Which 3ds Max version?
As a workaround, could you please change your system locale (not just language) to English US? Here is how to do it: https://www.tenforums.com/tutorials/132050-change-system-locale-windows-10-a.html
We will investigate if we are able to reproduce the problem.
(Internal ID=1012399973)
Hi, its win 10
3dsmax 2023.2.2
I Changed my system for non- Unicode programs to English United States
No changes, still cant put values
Thanks.
So you just start rendering anything and then try entering values like 0.8 or 0.9 in the VFB? Where exactly are you entering them? In the tone mapping operator values? If not, can you please show a screenshot where you are entering them?
Also, is there any difference if you use comma or dot? 0.8 vs 0,8
And last question: what exactly happens if you try to enter those values? Does it change to 0 or 1? Or maybe you cannot type at all and nothing happens?
Hi Maru, i think i found more of it
If i put just the " . " or ", " and then the number it will not work Example .7 Not working
If i start with the “0” and then “.” it works Example 0.7 Whis works
test made Using the new corona 9.1
We’re still not able to reproduce this here in the office, even on Spanish windows.
Can you try and change your region settings to English US?
Thanks,
Rowan
Besides the reply in the ticket I am also sharing the solution here.
The grouping symbol in Region and Language > Region > Additional settings has been changed from “dot” to “comma”.
This has also been added to the report.
Fixed in the latest daily which you can grab here: https://forum.corona-renderer.com/ Chaos Corona 10 for 3ds Max - Daily Builds Changelog #msg208744
Cheers
Thx!"
