Hello guys, do u have any plans to include a caustic multiplier?
I know we can multiply the channel in Post but it would be pretty useful to use it directly from the VFB.
Thanks for all your hardwork.
Can you please elaborate on how exactly you aim to use this multiplier for caustic from VFB? Is this something you only want to apply in post effects or in a pre-calculation stage of caustics? Something like Light mix? Have you tried Caustics solver settings? These are only visible when you have “Enable devel/debug mode” on in the Corona system settings.
thanks for answering Avi:
sometimes caustics are very subtle due to pool height, lighting conditions, or material setup, etc, the solution for this is to render the channel and duplicate it on Post, i made a mistake saying to use it directly from VFB, what i meant was to have a multiplier value for this porpuse, for ecxample, Vray has it in order to multiply it when u cannot see it and have it in render without a render channel in post.
Are you interested in a multiplier for caustics intensity (making caustics brighter or fainter) or in a multiplier for the number of photons (making caustics appear with better quality faster)?
I’m reading it as intensity/brightness… Changing the photon count can lead to quite unpredictable behavior such as (much) increased render times, noisiness and mostly leads to a different caustic look/result, probably not what OP means if he states he wants them to appear brighter.
+1 from me, having to resort to render separate channels and do it all in post is indeed cumbersome.
I personally like this idea. I often find myself doing Render Elements to allow me to apply brightness/exposure to the caustics in post, would be nice to multiply their brightness in the render itself without the post step being necessary (but still an option, of course
We have logged this feature request in our system to be further reviewed by our Dev’s. If there will be any update on this, we will let you know.
(Internal ID=1060673630)
Thanks Avi
