Change camera offset in python does not works
In order to manage tile rendering, i was used to (with vray 3.7) use command line listener method, with python code changing camera focal and cam offset X and cam offset Y. Actually i can change camera focal, but i did not found any way to change camera offset, it behaves like both camera offset (X + Y) are reset to “0”. My camera does have a VRay physical camera tag
I also noticed that Vray can not take into account camera offset when this one does not have a Vray Physical camera.. weird no?
Regards,
Well, i just figured out that using “pinhole” mode in the render settings override for the camera, force VRay to ignore offsets parameters (and others not very conventional i suppose…) So i let my cam as “standard” one, and it seems there is no merging problem with the rendered tiles.
Hello @f2b It seems like you have managed to find an answer to your questions. Thank you for sharing! I am sure other users will find it useful.
