Chaos Corona 8 Weird color output
Hello im trying the RC4 of Corona and when i try to apply a color in multimap appear so different in the VFBevery color looks with a red tint on it, i don’t know if im the only one with this trouble…
You’ve hidden the part we’d need to see :smiley: The tone mapping stack in the VFB.
And the Multimap set up, as it can blend the colors together with the Mix amount.
Can you specify which exact material is applied to that “pink” car, and what that material setup looks like? For example, the material may have a red/pink color set as its base color and this color may be mixed with the multimap if the amount of the base color is set to less than 100 in the maps section of the material.
