Chaos Scatter playground
Thanks for confirming! Just removes any possible source of confusion, much appreciated :smiley:
Hey guys, wanted to add my contribution here: I’ve spent some hours trying to figure this out for me and for some students that are having the same problem and just found another workaround. I still have NO CLUE what is causing the problem though. While looking for the solution, I tested the Unpacking method described here and got the same result as “josefane”. No chaos group folder appears. After some tries with admin mode, pausing Kasperky antivirus, and maaaaany other things, decided to test it on multiple computers and got to see with my own eyes that the “Unpacked chaos group folder” does actually exist. The problem is that, for reasons unknown to me, it either doesn’t get a chance to be created on some machines or it gets deleted so fast you can’t see it (don’t know which), so I imagine the same thing is happening during the standard corona installation process.
THE WORKAROUND:
Restarted windows in safe mode + networking, (unpacked files first just to see if the “chaos group folder” appeared, and it did), installed corona through the usual method and restarted windows.
EDIT: I was always using the installer from Download | My Chaos by the way
Hello, hope this is the right topic for general questions about Chaos Scatter.
It looks like Chaos Scatter is build “cross-platform” now and it can work with Corona and Vray.
I have a small question about licensing:
-Is it possible to use Chaos Scatter if I only have Vray license active?
Thanks !
Sure, but Chaos Scatter is not officially supported by V-Ray (yet). It might not work properly.
