When you click the list […] in Chaos Scatter in order to select multiple Distribute-On Target Objects or Instanced Model Objects you get the Exclude/Include Dialog. Shouldn’t you get the Select From Scene List Dialog?
The current dialog doesn’t even let you select splines. So it’s not of much use.
Thanks. The current dialog won’t let you pick splines or lights (which can now be scatter objects (thanks for that). So the second dialog would be much preferred. It also allows filtering and searching, etc.
