I’m experiencing a strange UI issue in Cinema 4D 2026.2, Windows, last nightly vray version / CPU only:
After doing a preview render in the V-Ray Frame Buffer (VFB), the UI partially stops responding :
Menus like “File” open, but submenus like “Save As” do nothi ng
No dialog appears (seems blocked or offscre en)
After waiting, it sometimes recovers, otherwise only a restart h elps
SINCE:
The issue started right after updating the AMD chipset driver yesterday (don’t know if this rel ated)
I also tested rolling back the chipset driver today, but the issue still occurs
What I tested so far:
Preferences reset → temporarily fixes it
Removed plugins (including CV Toolbox) → n o change
Clean NVIDIA driver install
Tested different scenes → issue only happens with a speci fic scene
After isolating the problem, it seems related to a V-Ray node material using displacement channel and no geometry tag. Copying everything into a new file, without that material and rebuilding that material and using a geometry tag fixed the issue. Any Ideas, what happened?
