Clean up a file
Hi guys, I like to start a little discussion
What it’s the best way to cleanup a max file?
I use a cleaner script from scriptspot but I don’t know if is the best way.
Someone have a better way or technique, mind to share :smiley:
Which cleaner script do you use? I did some research quite a time ago and ended up with “the” cleaner script:
Would also be interested in any reasonable alternative to compare.
But the imho best method to “clean” a scene (if it´s only about objects) is still:
  • save out selected what you really need
  • merge into a new scene
Good Luck!
I use “3dwannab-CleanUp.mcr” also..
Found it somewhere here http://www.scriptspot.com/forums/3ds-max/scripts-wanted/clean-bloated-max-file
Helps me alot!
I sometimes use this, although it’s probably included in the cleaner script:
t=trackviewnodes;
n=t[#MaxMotionClipManager];
deleteTrackViewController t n.controller;
gc()
I use this one, when I was searching for a cleaner tool this one was the most popular.
I will give it a try, thanks!
Sometimes simple could be better will give it try, thanks
