cleaner script and vraylight material
hi, when using the cleaner script and having vraylightmtl on the scene, the dialog says that the vraylightmtl has to be under vraywrappermaterial with GI off, otherwise can occur problems with Xref objects; is that a vray limitation working with xref objects? what would be the advise when using lightmaterials on an scene?
thank you!
anyone from chaosgroup?
