Is there a way to choose the color or material of the section or clipper in revit ? If not it could be usefull.
Hello @Blizard ,
In Revit, we don’t support the V-Ray Clipper but the native Section Box instead. To change the cut surface material, you need to follow the native Revit workflow, i.e.:
1. Under Revit Type Properties of the rendered 3D view, specify a Coarse Poche Material. This is usually set to Poche by default but you can change it to any other native material. (Mind that it will be applied globally to all cut surfaces.)
2. The specified material can be adjusted for rendering with V-Ray either from within Revit’s Material Browser or by replacing it with a V-Ray material in V-Ray’s Appearance Manager.
3. In the bottom Revit toolbar, set the rendered view detail level to Coarse. (If the detail level is set to Medium or Fine, the cut surfaces are rendered in the material of the geometry they belong to.)
4. Render
Best,
Ana
Great, thank you again !
You’re welcome! ![]()
