The VRay Clipper doesn’t render correctly after the 2nd image.
Clipper_error.zip (129 KB)
Hello @Doger ,
Thank you for highlighting this for us.
It seems to be a bug and I have reported it to our developers (bug ID: VC4D-1269) for fixing. I have also linked this thread to the report and I will keep you posted on the progress. Thank you!
Hey @Doger ,
It seems weird indeed but could please check the animation setup added to the attached scene with animation and etc. I think something in your camera setup is causing this behavior.
Cheers,
cube_size_2x2x2cm_mesh_is_clipper_animation.zip (140 KB)
I will check it carefully.
Hi Boyan,
this works but you are moving the camera and not switch between different cameras.
Maybe there is a problem with the stage object working 100% with vray?
Hi @Doger ,
It’s unlikely this issue to be caused by the camera as we also managed to reproduce it without having a camera in the scene. I have passed the collected information to our developers and I will keep you updated if we have more information. Thank you.
Hey, @Doger ,
I found a workaround for your task/s, It is a little bit slow as steps but is working. You will need to export manually the vrscene file and next to render with V-Ray Standalone in that case the behavior is not reproducible based on my tests.
Check the attached file for steps.
NEXT RENDERING WITH VRAY STANDALONE:
On Windows PC : Press “WIN + R” → type “cmd” and press Enter. Next → Find location of your vray.exe file by default for Cinema r25 is located here: C:\Program Files\Maxon Cinema 4D R25\plugins\V-Ray\res\libs\win64\vray.exe;
Select the exe file and drag and drop it to CMD. Next add sceneFile e.g [“C:\Program Files\Maxon Cinema 4D R25\plugins\V-Ray\res\libs\win64\vray.exe” --sceneFile=path_to_you_vrscenefile] → Press Enter
Cheers,
I’m also having this problem. After 1 frame the object that’s supposed to be clipped just disappears. Rendering with Vray Standalone isn’t an option since we need to do this on our farm.
I really need that to work in an animation too - deadline next week. Please FIX!
Hello @RwVision ,
Apologies for the delayed reply.
I have additionally increased the priority of this issue but I cannot provide any specific timeframes for when it will be fixed.
I will let you know as soon as we have any updates on the matter.
Thank you for your understanding.
Hi @aleksandar.kasabov ,
have you already been able to make progress on this problem? Since this error has already been fixed in the V6 Beta.
Hello @Doger ,
The issue has been fixed in V-Ray 6 Beta and we will see if it will be easy to pick it in the V-Ray 5 stable builds. I will let you know if we do that. Thank you.
The Issue has been fixed with the latest Nightly Build. Thank you very much!
