Cloud Rendering Issue - "vray-renderer container exited with code 134"
I’m using Vray 7.30.00 for Sketchup Pro 24.0.554 on Mac OS 26.4.1
I’m not using the last version because it doesn’t work and i spent hours to fix the problem, but the cloud render does’nt work too…
the log details :
02/05/2026 18:06:03 GI engines: ‘Brute force’ and ‘Light cache’
02/05/2026 18:06:04 Preparing renderer…
02/05/2026 18:06:04 Using Intel Embree ray server
02/05/2026 18:06:04 Preparing scene for rendering…
02/05/2026 18:06:04 startCameraTime=0.000000, endCameraTime=2.000000
02/05/2026 18:06:04 numCameraTMs=2, numFrames=2, frameSamples=1
02/05/2026 18:06:04 Creating bitmap manager
02/05/2026 18:06:04 Bitmap manager created.
02/05/2026 18:06:07 Light tree is enabled with clamp coefficient 0.1 and even split coefficient 0.5.
02/05/2026 18:06:07 Initializing built-in VFB.
02/05/2026 18:06:07 Resumable rendering is enabled - rendering can be stopped and resumed
02/05/2026 18:06:07 startCameraTime=0.000000, endCameraTime=2.000000
02/05/2026 18:06:07 numCameraTMs=2, numFrames=2, frameSamples=1
02/05/2026 18:06:07 Max ray intensity is enabled: rendered result may have incorrect brightness.
02/05/2026 18:06:07 Consistent lighting elements are enabled.
02/05/2026 18:06:07 Focal length 22.82672119 mm computed for target FOV 1.331063 rad (actual FOV 1.331063 rad)
02/05/2026 18:06:07 Preparing camera sampler.
02/05/2026 18:06:07 Preparing scene for frame…
recipe execution failed: vray-renderer container exited with code 134
I will try to render on my computer, even if it takes a long time…
If someone knows what’s this code 134, it could help…
Thank you
