CMasking_ID and VFB-Features, how unlink ?
Why “CMasking_ID / CMasking_WireColor” affected by VFB-Settings like “Expusure/Highlight Compress/Contrast/Saturation/etc” ?
Can i disable this ? To save manually this Render Elements i need turn-off all VFB-Features, reset all to default, than save Masks.
Not sure, maybe its bug ? I use 1.7 RC7 Version on 3Ds Max 2017.
“CMasking_ID / CMasking_WireColor” should NOT be affected by any of the vfb settings.
I have tried this in 1.7 RC7 and it works as expected.
Is this bug reproducable on your side? Perhaps you could upload some simple scene, where this occurs (https://corona-renderer.com/upload)
It would help us a lot.
Oh, sorry ! In VFB - all fine. Problem occurs only in “Corona Image Editor”. My mistake.
I use autosave function, it saves “.cxr” Files, when i open them “CMasking_ID” linked to Exposure/LUT/Curves/etc…
On - https://puu.sh/xTNTX/ef854c3aff.png
Off - https://puu.sh/xTNUN/812adb00e7.png
OK. This is known limitation of CIE (the CXR format currently does not define which elements should be color mapped and which not). We already have a task for it and it will be resolved. Unfortunately, the change won’t probably get to 1.7.
Hi, to keep you informed - CIE in next Corona v2 daily build will correctly limit tone mapping (and gamma) only to those render elements that are expected to be tone mapped, as it is in Corona VFB.
