Hi i work with the alpha 6 version and tried to use essential elements to build my beauty image.i’ve followed videos instructions and some topics here in the forum, but it worked only with .TIF 32 bits.i tried to do it with .EXR always overexposed image, tried with .png same result. can someone explain me why?, my purpose is to have the same beauty result with .EXR.
(in my trial i put highlight compression and contast to 1)(i use 3ds max 2013 and photoshop CC)
Thank you
It’s not exposure it’s wrong gamma. Make sure you’re saving your 32bit exr’s with gamma 1.0 IIRC automatic gamma was introduced only in max 2014, so depending on your gamma and LUT settings in max, you may need to override gamma to 1.0 when saving render output.
Hi, i overrided gamma to 1 i think as i read that in the forum, but i will to try to do some other trial…
Thank you
