Hi, saving the render as CXR and renaming to EXR to use cryptomatte in After Effects works properly, no issues there.
The problem is, saving as CXR does not rasterize the tonemapping in order to give more flexibility inside Corona Image Editor, so renaming the files to EXR discards the tonemapping and saves an overexposed raw mess
I can use batch conversion with the script inside 3ds Max from CXR to EXR and apply my tonemapping config, but this adds an extra step and takes much longer than just renaming. It’s not user friendly at all when converting, say 1500 frames of animation.
Tone mapping is included in CXR files as metadata so it is not “baked” when renaming CXR to EXR. I am afraid that the proper solution here would be to make Cryptomatte a “regular” render elements, and we have to wait for that. We have it reported internally.
I am sorry, but I’m not sure if I understand that. What exactly do you mean by “this process”?
If you mean just batch converting from CXR to EXR, then you can find the batch script here: https://support.chaos.com/hc/en-us/articles/4528237016721-What-is-the-Corona-Image-Editor#h_01FDT56CPJ15M39C6W4Z2B5VM7
After unpacking, you will see sample files inside. It converts all CXR files which are placed in the same directory as the batch script itself. If you need to change some options (like output file format) you need to edit the .bat file. You can use your own Postprocess.conf file saved from Corona VFB or CIE.
By default, it outputs all render elements, but you can limit this by editing the batch file.
May I ask if this issue has been resolved? I am currently using CORONA12 HF1 and have encountered the same problem as the author, Converting CXR to EXR to use Cryptomatte discards Tonemapping, I also use AE
This is not a problem. It’s the intended behavior. CXR has post processing / tone mapping information stored as metadata. If you rename it to EXR, that won’t apply the post / tone mapping information.
Instead of reporting a problem, can you please explain what exactly you would like to accomplish?
Hello, I would like to use it in AE. AE cannot recognize CXR format. If we change it to EXR format, AE can recognize Cryptomatte, but it will discard Tonemapping
Sorry, I just tested it and found that importing the mapped sequence directly into AE can work. The previous error was due to importing a Lightmix sequence,AE imported CXR, but the color is not consistent with Lightmix, it seems to have lost TONEMAPPING
Hi, can you please describe the problem? Do you mean the ability to see an image with its tone mapping as set in Corona and the ability to use cryptomatte at the same time?
If that’s the case, then I am afraid it is not possible. One workaround I can think of would be saving two files: a CXR (with cryptomatte) and an EXR (with tone mapping).
With plugins like Pulze Scene Manager you can set different file formats for different render elements.
This way you can save you main output as CXR, but add an extra Beauty Pass that will be saved as EXR.
