Converting Light Copies to Instances
I was looking for a script and founded this one on THE AREA is working fine for converting objects from copies to instances, BUT not for lights…in the selection window they arent show, i guess i should change in the following code the GeometrClass for something like LightClass, but isnt working so not so easy :slight_smile:
fn flt obj = isKindOf obj GeometryClass
src = selectByName title:"Select source" filter:flt single:true
dst = selectByName title:"Select copies" filter:flt
for i in dst do instanceReplace i src
Some ideas??
Mmmm no one??? :frowning:
ditch the “filter:flt” from the two middle lines and it’ll no longer use the filter that only allows geometry.
As another way, If your master light in your scene is called light_001 for example you can use:
-- leave the dollar sign in here and change the name of the object to whatever object you want everything to switch to
masterObj= $light_001
for i = 1 to selection.count do
	selection[i].baseobject = masterObj.baseobject
Thank you very very much joconell, both methods are working fine!!
Glad to help!
Hi guys,
just found this…is there a way to just make the master object which ever is selected first or something like that so that I don’t have to change the name of the master object everytime. Usually when I want to make lights instanced they are the same anyway but just not instanced so I don’t care which one is master.
Thx
for i = 2 to selection.count do ( selection[i].baseobject = selection[1].baseobject )
