Copying current channel from VFB: Copy background as well
Hey guys,
when copying the current channel from the VFB with the copy to clipboard button, can we make sure to copy the background image (using the background image function from the VFB) as well? Basically everything we see in the VFB should be copied.
Right now, I only get the RGB. But this is not enough, because I am using the Lens Effects and LUT corrections. And I can’t replicate the LUT corrections in PS, because they are handled differently there.
If a user does not want to copy the background as well, we would simply disable the background.
I also think that this was possible in one of the last releases, but maybe this was disabled.
+1 for this
Will make a note about this.
