This hotfix addresses some specific issues and all Corona 11 users for 3ds Max are recommended to download it.
Download now: https://corona-renderer.com/download
The issues are:
- Fixed a crash with the nodes group replacement in ObjectReplacer.
- Fixed issue where sun is disconnected from its target after loading a scene.
- Fixed DrServer crashing, when passing
--noGuiswitch. - Fixed color picker stuttering when changing values via HWB.
- Fixed crash when Chaos Scatter distributes empty Corona Proxy.
- Fixed issue where color picker was causing infinite restarts of IR and could display value with alpha < 1, when alpha was not being modified.
- Fixed rare crash in Scanned Material.
- Fixed issue where switching from one color swatch to another would change to color of the original color swatch.
- Fixed issue in DR where the values for 3ds Max version and maximum directory size were not remembered between sessions.
- (Scatter) Fixed issue where using Isolate would lead Scatter to recompute and thus slow down viewport interaction.
- (Scatter) Fixed an issue with the improper display of the edge trimming tip.
- (Scatter) Fixed incorrect edge trimming for instances of hierarchical/group models.
- (Scatter) Fixed edge trimming map usage detection for the hierarchical/group models.
- (Improvement) Added Gamma Correction tone mapping operator.
There are no other changes.
