Corona 5 3ds max
I cannot find skyportal corona light… have they disappeared?
ty
Hi! I am not sure what you mean - there never was a “skyportal” that I recall, just a Corona Sky, and a Corona Portal, so I am not sure which one you are looking for. Both are still there though, and their location hasn’t changed either (that I am aware of). The Corona Sky in Cinema 4D was changed, it used to be a tag on a native Cinema 4D sky, now there is a specific separate Corona Sky object (you didn’t mention if you are using Max or C4D, but guessing Max due to the location you are posting in, so, nothing has changed in that case :smiley: )
It’s not an object, it’s a material in Corona.
Yep, if the “portal” part of “skyportal” is the important bit, there never was an object for that - you create the geometry as a regular object in Max, and apply the Corona Portal material to it See https://www.youtube.com/watch?v=V5J2x2eIHUI
