Hi I am a c4d user and I have downloaded the alpha 2 version of corona, and I have noticed some very odd things, first of all corona is slower now loading a map in a corona material is slow, second the portals don’t work I followed a 3ds max tutorial, I have put some planes to covver the windows then applied a portal material but still the light cannot be distributed properly, the sun burns out the floor,it is too bright even with the intensity at 1, I can’t seem to add multipass, it doesn’t work or maybe I have read the updates of this new version properly, and still hdri not taken into account… I know this is still alpha, but corona is such a great renderer…
Hi, I went through all your remarks and it seems that every one of them is sorted out now. As for the Corona sun, it’s so bright because the default camera exposure works in indoor environments, but not outside. Outside, you’ll need to drag your exposure parameters down into minus values to look good. This is actually a feature of the renderer, not a bug.
