any chance to get a reverse button on “disable displacement maps” cause this is handy for test rendering, until you have to manualy reclick all the displacement maps in the scene back to enable -_-
The purpose of this button is to disable displacement maps in scenes where you do not know where the original author used them (like an evermotion scene). In your case you can simply turn of displacement in the render settings temporarily.
If I wanted to add an “enable” button I’d have to track all the states of all displacement maps in the scene (and save it somewhere). In the meantime, the user might be changing some of them or new ones will be added etc, this gets messy pretty quickly.
ok then… I thought it as handy to save time for test-rendering since using displacement on my computer chunks up memory + time, saving both for test rendering was “wauw” but manualy enabling everything again is rediculous…
thanks for clarifying
grts
@3dboomerang - You can already disable displacement in the render setup “Common tab” (just as DeadClown writes).
i know - it’s about re-enabling all the discplacement maps again -
damn - i mustave read over it somehow, srry, and thanks! - working so long with max now and i never gave that button any attention… happy again, tyvm
Hello i have corona renderer 1,6 version. I need converter for it from vray extremely(
Where i can get it, because latest versions on the site are not working with it ![]()
Can you send me please this older converter version? Thank you!
Hi. It’s part of the installer, so it should be installed with Corona. Look in the script folder or reinstall Corona.
