Corona Converter - unable to use file after conversion
Working on a large file 300mb, with 1.5gb of xref links. After converting the file using the ‘corona converter’ I am unable to use the file. It takes along time just to do the conversion ~1hr,and is almost impossible to close the converter after the conversion is done, all i can do is hit ctrl+s and save the file and then try to re-open it - but after 30+mins the file will open and continously flash and i cannot use any 3dsmax functions without pressing the button continously, waiting for a moment between the ‘thinking’.
vray can handle the file.
Is it the conversion which introduces problems into the file?
thanks
arkadius
Without seeing the file, there’s probably nothing that can be guessed at. You can send it along via the private uploader (Chaos) as mentioned on https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006-how-to-report-issues-3ds-max
