Hi guys,
I am sorry for this post but I am doing some lighting tests lately to find another artistic mood and in my mind I want to be Physically corrected and use the tools we have now available in the engine without cheating too much on the lighting parameters, colors, ecc.
Unfortunately, I’ve noticed that the Corona Daylight system is not very consistent on the lighting simulation of some specific timings during the day.
For the architecture photography, sometimes is good to take photos near 8:30 - 9-30 in the morning or later in the afternoon (I am not talking about the golden hour).
I took some samples photos here in Paris with my mobile phone, a Samsung S20+ and I’am trying to replicate the beautiful and warm lighting in the engine.
I attached the file “Real_Photos_Paris.jpg” to take a look. The light is warm, guite orange and the skylight has a beautiful and different color contrast from the sun.
Well, doing the same in Corona doesn’t produce at all the same lighting effect, the light seems too bright and too white. I’ve played with all the available parameters: White Balance, Color Tint, the Skylight parameters in general and have no luck! I’ve also noticed that the White Balance doesn’t separate beautifuly the sun color from the skylight color as in reality happens when we take a photograph. The skylight is less blue, the sunlight is less yellow/orange, I am refering on timing at 8:30 - 9:30 in the morning.
The only way to acheive a similar result is to cheat the engine and the technique in general! Use an HDRI bitmap as skylight, make it very blue (Kelvin setting) and bring the Sunlight to 3.000K and get the result!!! Yes, 3000K! But this is cheating right? But the effect is quite good! See attached image: HDRI_Sun_Test.jpg.
So to conclude, now that we have our lovely clouds and our Daylight system, are we sure the combination of the two elements, Sun & Sky is correct? Is it Physically and Chromatically correct?
I don’t want to use the HDRI + Warm Sun technique too much, HDRIs are beautiful but I’ve found sometimes their limitations.
What do you think? I ask too much?
Thanks in advance,
Dionysios -
