Could someone please tell me how to use this map?
I can only get it to work on polygons with zero thikness. It doesn’t work on an extruded spline even when height is set to zero and it definately doesn’t work on a box.
Maybe I’m trying to use it for the wrong thing - adding dirt and streaks. I have been using the AO map but wanted to see if this was better/easier.
That is it’s intended use, on objects with zero thickness. For boxes and enclosed geometry, CoronaAO and CoronaRoundEdges can do the same / similar thing, but those don’t work on zero thickness objects. The Edge shader is the reverse, does a similar thing on zero thickness, but not on enclosed geometry, so that there is something to cover all cases.
There’s the feature video at https://youtu.be/KBDVq-ZLFX0 that goes over basic usage of the shader.
Ok. Thanks!
Archviz Artist are showing a good use for it - coloring plant leaves, although the leaf borders need to be edges; opacity-mapped rectangles won’t work.
https://youtu.be/1bBlGsngJhM?si=PbMeQjboC022Qco1
Another idea is VFX - for example imagine that a surface is fragmented into small parts (but larger than a single polygon). You can’t use other maps there to color the borders of the fragments.
I used it with really good results to have white lines (street markings) all around streets and parking areas.
