Hi
Usually I’ve a directory with inside all my best IES files.
if I want to change a IES file in Corona light (inside there is already a file ies), then I click th e"open" button, Corona forgets the previous IES path.
So I have to search again every time… Annoying bug.
Better is the possibility to have inside corona light a full list of my favorite IES file.
In this way, I don’t to open every time a browser windows.
Also I’m not able to see the name of the IES file inside the Corona Light ![]()
I will try to solve this when I move all paths into 3dsmax asset system
Thanks ![]()
fixed
Ohh, thanks. This was an annoying problem ))
I don’t want to start another thread and it’s kind of related:
Is it possible to make Max automatically add used IES files to the archive when doing file>save as>archive?
Also a minor issue: in Corona light’s parameters please make the whole path to the use IES file visible or at least the name of the currently picked file. It’s sometimes annoying when I want to use the same IES file in a newly created light and I don’t remember which one I used previously. ![]()
Unfortunately, path bug not fixed…
