Corona HDRI with simple UI such as vray HDRI map have, easy to control easy to rotate swich dialog between modes.
Corona light dome (not critical) It could be helpful in situations when for example fimefx should be lit by HDRI (By the way corona is the fastest way to render fume sofar) and it would be very cool to have ability to render it with hdr lithing not a number of fake lights to match the actual lithing.
- Why would you really need this? What’s better in Vray HDRI than in CBitmap?
- Why not just use enviro map?
Corona dome light is not planned. There are other threads for the Corona bitmap UI - it will definitely get some UI polishing
Because light domes make it infinitely easier to switch between different hdrI : Simply turn them on and off
They also make the rotation of the hdri simpler and more intuitive
sorry.. I cant find that thread.
if there is someone know where it is, a link please
I have some ideas in my head about corona bitmap UI.
