Corona Image Editor Sequence/Batch
Was trying the new Corona 1.7, very awesome CPU renderer. The one thing I liked was the Corona Image Editor which I didn’t even know existed. Would be awesome if the Corona Image Editor can load and handle sequences, or there be a batch render for the Post work on a sequence or folder of images. This would enable to do post on animations.
https://coronarenderer.freshdesk.com/support/solutions/articles/12000030886
There is a batch editing script on the bottom of the page. The usage is that you’ll load one frame into the editor, modify all the post processing settings to your liking, then export/save the settings and use the script to apply them to all frames.
Thanks for the info Ryuu, it seems it doesn’t take .EXR for batch though. Only .cxr, or am I wrong? Would be nice to have that built into the actual CIE.
AFAIK it should work for EXR files as well. Just modify the file extension from *.cxr to *.exr on line 35 of the CoronaImageBatch.bat script.
