I have the newest C4D version and downloaded the newest Corona release. Everything was working fine until I got a low on memory error while rendering a scene. I stopped the rendering, closed down cinema, unnecessary applications to free some ram and proceeded to render the scene again. This time all of the materials rendered black. I made a new project, created a cube, new corona material as white and applied it to the cube. Even in a new project the applied material renders out fully black. I don’t know how to fix it.
Yes I do. For that scene if I open the corona renderer it shows the exact same thing. For this cube if I open the renderer and press render it just opens the standard renderer.
The cube scene renders just fine for me (after I made the default renderer to Corona). The room scene renders black because the textures/paths are missing. When you save the scene, choose save ‘project with assets’. Otherwise, others will get the same result.
[/quote]
So I reasigned the directories of the textures and now it renders out in colour, thank you! However in a new project like the cube when I apply a corona material and proceed to open the VFB, after pressing Render it just opens the picture viewer. Pressing interactive renderer works though so I should be alright from now on. Thanks again!
[/quote]
[/quote]
In Cinema’s preference settings, go to the Corona tab (at the bottom) you can choose if you want it to render to the PV or VFB as default. Hope that helps.
