Corona Multi Color
Hello everyone,
I am trying to create wooden floor like the image attached in corona 4. I tried to watch corona multi color tutorial but could not make this kind of floor. If anyone can share a 3d max file with corona multi color material for wooden floor I can learn from it.
Any help is apreciated.
Thankks
I guess you are referring to CoronaMultiMap, did you by any chance take a look at this: https://coronarenderer.freshdesk.com/support/solutions/articles/12000004978-how-to-use-the-corona-multimap-
Please also use attached, depending on your floor setup you will have to change the “Mode:” selection. Please let us know if you still need assistance setting it up.
multimap_floor.max (1.32 MB)
Or you can use CG source multi-texture and add you bitmaps there. Works well with floor generator.
thanks man It worked. Regards
glad it helped, if you need any further assistance ping us back.
