Yes, sadly: “Support for Cinema 4D R14, R15 and R16 has been removed (These versions are really old and required lot of maintenance time that we can now focus on improving new and existing features).”
Otherwise, you’d find it in Corona menu, right under Corona Hair, there’s Corona Pattern.
so it remains to buy a new cinema4d where half of our plugins don’t work or other render engine…and the price remains the same for old version/the last working one of corona if we don’t change render engine.
Disappointment on every point
That’s a hundred years ago in software terms.
Of course no one wants to be forced to upgrade all the time - but you can’t realistically expect software that old to be a viable option in 2022.
We are not even forcing anyone to upgrade - older versions of Corona run perfectly fine with R14+. We just cannot provide new features to people who opt in to stay with 10-8 year old host application.
If you want to use R16, you can use any Corona version up to v8. If you want to use the features introduced after v8, you need to update your host application. Same way as you cannot combine 2010 motherboard with 2020 CPU, for example. If the last usable version of your host application is 8 years old, the problem is really somewhere else than Corona cutting support for it…
I would love to see a little video or manual on the new pattern modifier for settings like object space/world space or whole or crop box and xy, zy and xz. It seems all very straight forward though but I am getting all sorts of unpredictable results. An example file with some presets would also do.
Its so busy here at the office that I dare not try new features. The pattern modifier looks great though.
It’s just because of other plugins that are “must have” at work and speed up the implementation of projects.
And these plugins don’t work in the newer version of cinema4d.
that’s why we are on old versions of c4d.
we will study what this means for our workflow and what is better…use new base c4d without plugins and drastically slow down the process or change the render software
Did a quick test with Arroway 3D gravel. Imported the gravel mesh as OBJ and made a corona material with the by Arroway supplied image maps. The UV’s where already imported/placed with the Arroway meshes.
The attached render test where done on my MacBook Air m1 with 16Gb. Testrenders only a few minutes.
Amazing these 3D gravel meshes can now be used with Coronarender in such a simple way.
The test render is a Cinema4D landscape of 20x20 m with the 2x2m Arroway mesh tiled at 10 x 10 (U/V). Time to first pixel is actually very fast. But I had to switch the Pattern modifier of to have any kind of viewport speed. With the modifier on I couldn’t zoom or pan at all.
Indeed, and the pattern modifier also cuts the pattern at the edges.
I can speed the rendertiime up by a lot since Arroway provided these gravel patterns in two layers on top of each other. I used the two layers and I think I could have just as well used only one. This pattern modifier is really a big step forward.
Yeah, trying out the Corona Pattern myself right now and I don’t get it at all. Even with the 3DS Max guide open. C4D is missing the Pattern Node selection, right?
Edit:
Ok - working now and I get to see something.
Important: Only visible in render and the base object needs proper UV layout. Setup looks like in the attached screenshot.
Now I’'ll try to get some control over all what is happening there. Looks promising!
