There are cracks on the edge of the Corona Pattern Modifier, how to get a normal result, VRay Enmesh Modifier looks correct
This depends mostly on the UVW coordinates of the faces you have. Unwrapping or face UVWmapping each polygon will be the solution here.
VRayEnmesh and CoronaPattern do work differently (you cannot have overlapping geometry with CoronaPattern e.g.) but I don’t think this is the case for you and this is absolutely achievable with CoronaPattern.
You can as well share the scene here to check it and fix the issue.
Thanks for your replies, I’ll try again
