Hi. Are proxys working in v5? I can create and load them in but the textures are missing. ![]()
Yes, proxies are host software independent (Max, Cinema, Sketchup, …), so they don’t contain material data. What should work (but unfortunately doesn’t) is assigning multiple materials to the proxied object, if the object contains multiple polygon selections. In that case, each material being successively assigned to the object will be assigned to the corresponding selection. However, as i already mentioned, it currently does not work, which is a bug.
This has been fixed already
