Corona Proxy Exporter Output options
This may be quite a random request but one that I hope others will back!
when creating a Corona Proxy object, the button to choose the location of the proxy that opens the browse for folder window, takes me to my machine, rather than the location that is already listed. Corona is excellent at saving time when rendering and therefore enabling more time to be creative, but the fact I have to navigate every time to the correct server location to save a new proxy is very time consuming when I am making multiple proxy objects that need to be saved in to a specific folder. I need this to keep our asset library nice and tidy.
Is there a way the browse for folder option, can take me to the path that is already listed within the button to speed up this process? Less mouse clicking is always a good thing!
Many thanks,
Andy.
Sounds sensible.
Meanwhile you can check if loading proxies through the asset tracker would not work better for you (I am not sure myself - just guessing).
Update: yea, doing this through the asset tracker seems to help. I remembers the current path.
I’ll log it anyway, because why not have it in the proxy ui. :smiley:
(internal note id=319923035)
Thanks Maru,
Yes no issues there, asset tracker always seems to load to the path that is set for a proxy or bitmap previously set. The problem is when creating a new proxy and using the Corona Proxy Exporter. If you can get that in that would be really helpful!
Thanks in advance.
Andy.
